Oh that's mad that, my Gigabyte Aorus 3080 Master fits my x570 Tomahawk in my case, I do however have 2x M.2 drives only.
Hey buddy, I have the Noctura NH-D15 chromax.black installed with this MOBO and I've got all 4x RAM slots occupied, my memory is https://www.overclockers.co.uk/team...3600mhz-quad-channel-kit-black-my-095-tg.html,
Here are the RAM clearance info from their website too, I had to refer to this also: https://noctua.at/en/how-big-is-the...e-does-it-provide-for-ram-and-chipset-coolers
here are the dimensions from Team Group's website for my RAM: Dimensions 48(H) x 134(L) x 9(W)mm,
You might need to make sure you have a nice sized case as you'll need to lift the fan a little higher due to the size of the RAM.
I hope this helps, happy building!
I think you can take the heat spreader off that RAM if you want to move your fan closer to center.
