Show me your: Fireplace
20 May 2007
Swapped this monstrosity
For this
14 Apr 2007
@{SAS}TB How much did it cost all in?
The house we have an offer on has a near identical fireplace and we want to change it to a log burner with a nice thick wooden mantel.
20 May 2007
It was removed / fitted about 3 1/2 years ago and was £3k for removing / disposing of the old gas fire / surround and hearth, forming the opening, liner, cowl, skim the opening and breast, oak mantle, slate hearth and the stove. The stove itself was ~£900
Hope that helps
14 Apr 2007
Hope that helps
Thank you!
4 May 2007
West Midlands
Really like that @{SAS}TB Ive infact stolen the picture as an idea for the replacement fire in my new place. Its got a fire/chimney but doesn't have as deep a chimney (all flat /see pics below)
Have you got a wider picture with the tv adjacent? How big a tv you fit adjacent?
Im also tempted to go with a gas fire, as i have a local gas supply to it, so seems to make sense.
Pics of house im buying:
JRJ
JRJ
21 Oct 2010
We installed this a month or so ago: it’s Contura i5 and installed by a local company.
Exact fire my wife has been eyeing up, she wanted something a bit more modern looking than your traditional fires, out of curiosity what are the dimensions HxWxD of your opening?
20 May 2007
Cheers and here's a few just taken now so ignore the mess :p
The TV is 65"
12 Jan 2005
Norfolk
Dimensions are:
94cm W x 96cm H x 75cm D
We’re really pleased with the purchase - packs a lot of heat and very easy to light / clean etc. If you’d like to know anything else about it, feel free to ask.
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
We have a double sided fireplace. It wasn’t planned but when we took out the old 1950s stove it made a nice hole from the kitchen into the living room.
JRJ
JRJ
21 Oct 2010
Dimensions are:
Thanks @Dolly I've currently got a 1m*1m opening which will be lined and tiled, but only a 450mm depth plus the legs of the fire surround so probably 550mm max, yours looks like its sitting quite far back in the opening?
