Worktop as desk, drilling legs? (plus other questions)
3 May 2004
Hi all,
Looking to buy a wood worktop (either oak or walnut) to use as a desktop as I've seen many users do here and looking for a little advice.
Are IKEA Adils legs good enough to hold the weight of the desktop?
The plan us to use my current Alex drawers on the one side and 2 Adils legs on the other. (1500mm x 720 x 40 if the dimensions matter)
If so, whats the best way to attach them to the desk?
Drill a hole out first and then screw them in or just screw them right into the wood?
Would I need any certain wood screws/drill bits for this?
The retailer Im looking at will pre-oil it with Osmo Top oil for an extra £20 (three coats), is this worth it or shall I just do it myself with Dainish/Osmo?
Thanks for any help all!
As for the oil, it depends how much you value your time - £20 for three coats of oiling/sanding doesn't sound too bad, you'd be paying about that for the oil itself probably?
can you get a 2 meter long solid oak top, and then just lob some off down the side to get the length you want?
asking for a friend
On a side note, have you thought about wrapping your table top to get custom designs?
Earlier desk thread had some alternative, more stable, 'H' style end legs ... I quite like beech faced ply, for the better strength/weight, edges look nice *if* you can finish them.
Thanks for the advice everyone, looking forward to getting this together.
Any idea what these were called or where from?
I would have thought a 1.5m desk would need a centre support.
I'm not so sure I've seen bigger desks with no center support and appear to be fine.
Anyone else know better?
If your top if thick enough you won't need the central support. I'm all for a wooden slab, as if and when you mark or stain or damage the surface you can sand it down and oil it up and carry on. Done a few of these for the workshops at work. They last much better than the tops with like a vinyl or synthetic cover on them
