Hi all,
Looking to buy a wood worktop (either oak or walnut) to use as a desktop as I've seen many users do here and looking for a little advice.
Are IKEA Adils legs good enough to hold the weight of the desktop?
The plan us to use my current Alex drawers on the one side and 2 Adils legs on the other. (1500mm x 720 x 40 if the dimensions matter)
If so, whats the best way to attach them to the desk?
Drill a hole out first and then screw them in or just screw them right into the wood?
Would I need any certain wood screws/drill bits for this?
The retailer Im looking at will pre-oil it with Osmo Top oil for an extra £20 (three coats), is this worth it or shall I just do it myself with Dainish/Osmo?
Thanks for any help all!
