- 26 Oct 2013
- Scotland
It's weird how many people are talking like this is absolute confirmation, I thought most on this forum were better than that.
I've already pre-ordered the 4080 from OCUk, so I should be able to get one on release.![]()
The exact spec, no. The possibility of Lovelace before Hopper due to Ampere being on 8nm and eating a lot of power sounds valid.
Yeah I can see there being a shrink before a new architecture but a lot of comments on here were a lot more about it actually being what has been stated even though we should all know better than that.
If the games are vaguely demanding it will be 4K, 45fps.The 5080 is going to be at least 120TFLOPS. 4K-120 for all!
For me it's quite evident that performance has hit a wall now against power consumption. These GPU's are at the edge of acceptable power consumption if you ask me.
750w - 850w is probably as high as they can go for a consumer based gaming GPU.
I cannot see them making more powerful cards with increased power requirements. It would be crazy.
my 3090 at 410w has hit that wall.
It's pumping out so much heat in the case that my other components, especially the x570 pcb is getting close to their maximum safe temp range. (Keep in mind I also have a 5950x overclocked at 250w).
If I add any more heat some of these components will start causing system crashes. And I have a very airflow focused case, there is just a limit to how much heat can be dealt with. If I did add more heat, I would now have no choice but to move to custom water cooling
a 120tflop card is almost equal to 4x 3090. Control with rayvtracing maxed out at 8k and no dlss runs at 10fps on the 3090, so the 120tflop card would do 40fps... at8k, never mind 4k
Yes but I said 'vaguely demanding' meaning more demanding than 'Control' which doesn't even bother to render half the destruction in RT reflections. I'm assuming games will actually start to use RT to create images such as water and reflections that are a significant advance on what we have today rather than to a similar standard to how it's traditionally been rendered with a gimped non-RT version to showcase how 'great' RT is. A fourfold increase in performance will be good but it's just a step in the right direction as we can expect the level of game design and complexity to continue to increase as it always has.a 120tflop card is almost equal to 4x 3090. Control with rayvtracing maxed out at 8k and no dlss runs at 10fps on the 3090, so the 120tflop card would do 40fps... at8k, never mind 4k
At 4K that would depend on what fps is your target. I always lock mine to stay either at 57fps (like in cyberpunk) and 60fps for other games that need 60 to run properly like Mortal Kombat 11. My 3600 never gets fully utilised trying to hit 60fps.I can see CPUs becoming the major bottleneck soon. With the current CPUs, there is a bottleneck at 1080P and even signs at 2160P, chuck in a beast of a card and that 4K game is now held back because of the CPU.
If Hopper was ever going to be MCM design ghen it was never destined for consumers Graphics.
That said obviously there is more to it than that and I may benefit from better minimums etc with a 5600x which has better IPC or some other intel cpu, but for now I am happy for another year at least.
Want see what Intel and AMD bring with their next gen offerings and decide if I will go to a new platform or just grab a discounted 5900X and be done with it it for the next 5 years.
More people not understanding the MCM approach which is mostly likely to be employed for consumer graphics. Everyone seems to be locked in a vision of Zen like chiplets.
the heat issue has put me off a 3090 now even my 2080ti zotac gets hot .
