- 21 Jan 2003
- Northamptonshire
Hi mate! Yes its the regular O11, i had the same issue so i created this to solve it.
I used parts from a EZDIY vertical mount and modified a Phanteks vertical mount to make this mount so i could adjust the height and allow a thick radiator to be fitted at the bottom with standard height 25mm fans.
Nice one,
Thanks for that, could I trouble you for some pics of the creation/mount if you have the time
Many thanks,
