Wall mounted the monitor and liberated some space on my desk. Also repainted.
My wife's 'Mac' side:
Where did you get that wallpaper from (the snowy one)?
That looks really greatSo... I did a new desk build.
Away with the IKEA Malm. In with, a full kitchen?
Full thread with more pics in the build section:
https://forums.overclockers.co.uk/threads/lockdown-pc-setup.18888192/page-2
It's an animated one I made for wallpaper engine. I've uploaded it on Steam - it's called 'Tundra'.
Edit: made a bigger stand this afternoon for the DAC and a USB hub. Also got the Pitikapp sytem monitor software running on my iPhone. It's a nice little free app and easy to use / configure.
Can I ask bud, how do you mount the monitor on the wall like that? Do you need to drill into the studs or something?
Ah cheers, bud, would you mind linking to the kit in question?Can I ask bud, how do you mount the monitor on the wall like that? Do you need to drill into the studs or something?
Not finished but it's getting there
Need to get some basket to assist cable management
^^ Like that, just needs a massive monitor in the middle wall mounted![]()
Are these interchangable with the panel that you get ? E.g. if you upgrade?
Which LED light are you using here bud thats some pretty power lighting!
Does anyone have recommendations as to where I can buy a desk that’s deeper than 80cm. It’s actually quite a tedious thing to search for on google!
I ideally want something 90cm deep and with a seeming lack of any other options I think my best bet is getting a kitchen worktop and adding some legs to it.
Yup this is what I’m going for... just get some table legs on the thing.Kitchen worktop is the way forward. A standard one won't be deep enough for your wants there, but an 'island / breakfast bar' section will be. Very easy to cut to size also if you find a section bigger than required.
did you get a tradesman in for that?Can I ask bud, how do you mount the monitor on the wall like that? Do you need to drill into the studs or something?
eBay or Gumtree. I got mine (dark solid oak) from Gumtree after a bloke finished his kitchen and had it left over.Does anyone have recommendations as to where I can buy a desk that’s deeper than 80cm. It’s actually quite a tedious thing to search for on google!
