Why would you get a new router? You will still have to use the Virgin hub as your modem so it won't fix any of your issues and if you want better wireless LAN you'll probably be better off with an access point.
A better router is always suggested though isn't it. The superhub 3 isn't very good at anything. I'm aware it might not fix my speed issues, I've got an engineer that will hopefully resolve that
