Nice looking white option for ear buds, decent length cabling. Could do with cable ties or white Velcro straps to tidy up the wires. Not bad for £14
i like my AMVR ones at £15
Ordered a "1ft" right angled USB-C cable off eBay. It arrived today and... the moment I looked at it I knew it wasn't right. It's only ~28cm long, including the connectors. The cable itself is only ~24cm long.
Bit annoyed. Means the cable will have to be unplugged when I put the headset on/off. But it's better than the 1m straight cable I was using. Just a word of warning to anyone looking to do similar really; buy 1.5ft if you can find it, or 50cm if you can't. There will be slack, sure. But at least it'll be long enough.
Is this for a battery pack?
Yup. I could have been clearer about that![]()
I just filmed myself doing a few rounds of FitVR boxing. My god I look like a ******* idiot. This really is just for the privacy of ones own home with the blinds closed. I'd rather be caught masturbating![]()
you can get them in white too
Also you can buy branded ones, they are Logitech R333 i think, expensive though
and not available in the UK
Without getting into trouble, can you provide a linky to the white ones, as everything takes me back to black. This would make an excellent title to a song btw.
its G333 not R333, google should bring them up![]()
