what's the energy use and time for a pre-heat - the 64K question
wheel arches are still faily obtrusive
https://www.autoexpress.co.uk/hyund...ndai-kona-prices-and-specs-announced-pictures
but bonnet nicely panamera'ish ,
there must be significant cost(accident repair?) saving with these wheel arch designs versus other cars with single piece wing, or rear quarter panel.
...am I missing something ... is the insert all plastic, even if its now body coloured ?
Between 3kW and 7kW depending on the initial outside temperature.
That’s the ICE facelift. This is the Electric. They’ve ditched the plastic cladding for better aero.
https://www.autoexpress.co.uk/hyund...-kona-electric-facelift-arrives-bold-new-look
less so on the ev update picture WJ just uploaded, but, compared to many suvs it looks like a large(inelegant) molding bolted into the wheel arch, must simplify construction/cost somehow, but still provide crash rigidity.Those arches are purely to make the car look ‘SUV like’, it’s nothing to do with accident repair costs. Loads of cross overs have them these days.
The front end looks very Tesla like, which isn’t necessarily a bad thing...
how much energy ? largely irrespective of source, but if you could use the 'mains' there would be less losses, but, as discussed before, you'd pay daily unit rate.it was how much battery it took to heat the car. And in the case of the Tesla and the Kona, it’s between 3kW and 7kW
I apologise I’ve missed some subtle difference between the energy consumed to heat the car and the power demand. As I understood the question, it was how much battery it took to heat the car. And in the case of the Tesla and the Kona, it’s between 3kW and 7kW. Contrary to popular belief, the cars usually use the battery to do anything and if they’re plugged in, they have to restart charging to make up for the energy used to heat the car.
edit: indeed (marmite) tesla like .. is that the reference pattern now ?
7kW for 15mins is ~1.7kWh. For a trip of 6 miles you might have just doubled your energy use. Whilst still talking about 4 miles/kWh.
It’s just science.
Ah, I beg your pardon. it only runs for 20 minutes maximum and shuts down. So 3kW in 20 minutes would be 9kWh and 7kW in 20 minutes would be 21kWh. It's massive. There is a whole sub-thread in the Tesla M3 thread about pre-heating and the effect on fuel economy for short trips.
I suppose all the cells are in series/solicited, so you have to heat everything up, otherwise, partial heating would be good,..... or just keeping it in a garage(bigger benefit vs an ice) -And of course a preheating cycle is more of an issue with the larger batteries and greater thermal mass
Given the posted screen shots of the gui, I had thought this information would be geekily presented automatically
Pre-heating in the Ioniq had been great over the last week or so, since the cold spell started really.
Don't have mine plugged in, uses a couple of % and takes no more than 5-8 minutes, ready to get in a nice toasty defrosted car without ever leaving the house.
No, I think it's right. I'm reading the % battery numbers off the screen so if it uses 5% battery in 20 minutes to heat the car and the battery is 64kW then that's 3.2kW used in 20 minutes so its 9.6kW/h. And if it's really freezing outside and I put the defroster on as well it uses 11% battery which is 7.04kW in 20 minutes which is 21.12kW/h. No?
Many compound units for various kinds of rates explicitly mention units of time to indicate a change over time. For example: miles per hour, kilometres per hour, dollars per hour. Power units, such as kW, already measure the rate of energy per unit time (kW=kJ/s). Kilowatt-hours are a product of power and time, not a rate of change of power with time.
Watts per hour (W/h) is a unit of a change of power per hour, i.e. an acceleration in the delivery of energy. It is used to measure the daily variation of demand (e.g. the slope of the duck curve), or ramp-up behavior of power plants. For example, a power plant that reaches a power output of 1 MW from 0 MW in 15 minutes has a ramp-up rate of 4 MW/h. Hydroelectric power plants have a very high ramp-up rate, which makes them particularly useful in peak load and emergency situations.
Other uses of terms such as watts per hour are likely to be errors.
