- 8 Jun 2018
Like I said beforeA very large proportion of IP never makes its way in to a product of service. Often companies purposely file patents they have no intention of using, solely to limit their competitiors freedom to operate in a space.
One thing you can almost guarantee with games related tech is that if something was being done, gamers would find a way to evidence it... People have been claiming for years that FIFA exhibits a 'momentum' mechanic but I do not believe any evidence has ever been brought forward to show it. EA have always said it does not exist.
'The same level of critical thinking applies to the patent when you factor in evidence that can be
Anecdotal, Analogical, Circumstantial or Demonstrative.'
What you are objecting to is something called a false equivalence. Where you cannot prove what Activision is not doing with the patent. Only what you believe some other business didn't do with their patent. Which really doesn't suggest that Activision isn't using it.
Now you can choose not to believe it. It's your choice. But it's not proof that it is not happening. Those are 2 very separate constructs. For example, you can choose not to believe that the sun won't shine tomorrow. While I believe that it will using Anecdotal, Analogical, Circumstantial or Demonstrative evidence presented so far. It's not absolute proof that the sun will rise tomorrow. But based on what I have so far the evidence does suggest that it will. Therefore, I choose to believe that it will.
It's worst in CW then in MW. But if you go back to BO4 it wasn't that pronounced if at all.This is happening in black ops cold war right?
first 10 games or so was getting KD ratio of 7:1 and it felt easy, every game after that the players are much better and the KD ratio dropped to 2.5:1
But sure, you can go on a several win, high k/d and will suddenly find yourself up against some sweats. For me I usually notice it within 5 straight wins in a row. It's how they program the algorithm.
