MKBHD skin from dbrand, was ordered back in November as was on a limited edition shipping after Xmas. It finally arrived
Nice OnePlus logo right in the centre for your Samsung to hide behind.
That's a shame, but how are the pads? I will need to replace mine again soon.
Immediately I noticed the soundstage is much more central and songs and media that once felt airy and open in detail felt enclosed. The highs were not as crisp any more either.
I should have read the Dekoni website as they kind of allude to this with their own overview and freq graph - I had just assumed they would be just as good as the Velour.
Anyway, I still have the stock pads so I put those on and am hearing the open air detail once again.
To be honest now, given the cost of importing and the overall cost, I will now stick to stock pads. Not as comfy as memory foam, and the bass depth is slightly less punchy, but the soundstage is perfect and they don't cost much to replace.
Just thought I'd give a heads up to anyone out there still on the fence about either for their Senns.
The suedes do look superb though and feel so nice, just a shame about the sound presentation![]()
Honest opinion? I've had some time with them now and luckily I still have a pair of orginal stock 650 pads that I bought spare brand new and never really used as bought the Dekoni Elite Velour shortly after which I've had for a couple years now.
Honest opinion of the Choice Suede pads is that they are extremely comfy as you would expect from memory foam pads, but the sound is too different. Here's what I said on reddit:
So if you do want more comfy pads and want to retain the stock sound just with better bass response then buy the Velour Elite pads, but if the cost + import fees is too much, buy the stock pads instead.
It's going to cost too much to return these so I'm kind of stuck with them sitting in the box in a cupboard, I have now gone back to the stock pads. I may well just put them on eBay though to claw some funds back.
Slightly annoyed, bought the new Dekoni suede memory foam version of the earpads I had before (velour memory foam) as the odl ones had started to tear on the inside. Came from the USA and today UPS rinsed me of £18.65 worth of fees!
Those cartridges don't fit in the jugs pictured behind though?
They are for water filter jugs yes, just not those Philips ones in the back of the photo.They look like they are for jugs.
4 different types of jugs i own![]()
Blimey! Do you use different filters for different uses, e.g. coffee machine vs. cooking etc?4 different types of jugs i own![]()
4 wives?
