One is a 12v power supply (that I don't need) and the other is a re-set button (that I might need). My soldering is ropey at best, I have a punch tool and have done loads of patch panels and sockets, but I never terminated the cables onto rj45 plugs. Are the cheap rj45 crimpers any good? Is it quite easy to do?
I'm going to investigate split glands or maybe just try cutting one in half/dismantling it as that looks like it could be the easiest solution.
It's doesn't need to look amazing, I just don't want loads of trailing wires and want everything sealed from the weather.
Dave
Dave
