Hi all,
I hope you can help, I have a second PC with a 980Ti in. I booted it up recently and everything 2d was absolutely fine, but the moment I loaded a game it started artifacting and then the display switched off. Upon booting the PC now the DisplayPort shows a connection but then instantly turns off again, the GeForce light is on and the Fans are spinning so the card is receiving power.
Is the card toast or is there anything I can do to salvage it?
thank you
thank you
