And another one -Hi-vis fails all too often when drivers don't bother looking... https://www.manchestereveningnews.c...er-news/police-officer-cut-car-after-10189280
Making this a slightly meta topic:
I cycle a lot and frequently experience joggers in my cycle lane, going against the flow of traffic, at night, with no reflective gear on.
Annoys the hell out of me.
I think if you walk aren't you meant to go against the flow of traffic? Its not hard to wear high vi's, I've seen some cyclists wearing this jacket that flourecss (not sure on spelling) whenever light catches it, makes it pretty obvious when are there.At least they can see the traffic I guess. I've found joggers without reflectives and back to traffic in Richmond Park when it's absolutely pitch black before (besides the portable sun on my handlebars). Crazy.
cyclists with lights in the uk - should also realise, a light alone with ninja suit, does not catch motorist eye as much as a few square feet of high viz.
Wearing bright coloured clothing, having flashing lights on whilst in broad daylight does not catch motorists eyes quite often. Some motorists just don’t look properly, if they don’t see a car or bigger they just don’t see anything. It’s exactly the reason why cyclists and motorbikes get pulled out on so often
Yes. That's exactly what I'm saying.I think if you walk aren't you meant to go against the flow of traffic? Its not hard to wear high vi's, I've seen some cyclists wearing this jacket that flourecss (not sure on spelling) whenever light catches it, makes it pretty obvious when are there.
The blue hi-vis works best I think. You see blue before any other colour which is why blue light stand out so well.
pavements get coated in a thin layer of ice from the frost where I live far quicker than the road surface does.Loads have started running on the roads now where I live I'm guessing because the roads are more grippy in the cold conditions at the moment.
who knew ?google green for max sensitivity in daylight but shifts to blue/500nm as it gets dark.... I usually run at dusk; seems those blue car lights may have more benefits.
irrespective personally went for orange, works good in fog and gives more contrast versus most surroundings, looking like grass/sky in daylight may not be ideal.
the coloured section of the viz jacket is not usually retro-reflective anyway (ie reflecting back car headlights) the retro-reflective bit is colourless for max efficiency - some kind of metallized particles
The condition for barely being able to see for blue to be the best colour is not good and wouldn't apply to a headlight since it immediately removes the low light issue.
Guess we're back to all wearing black then since apparently headlights stop it being an issue!
You sure about that.
Stupid thing to say.
We'd wear colours to reflect light we have high sensitivity to. The blue factor applies in extremely low light levels which you wouldn't have in front of a headlight.
It's definitely green, which is why my bike lights are green LEDs they especially help with terrain definition off-road.
Also in my shooting days why green lasers were used as they're easier to see than the standard red.
Also why trendy blue tint car lights aren't especially good Vs yellowish tint. Yellow being a bit behind green I think.
