Advice on new build
23 Apr 2020
I think I will go for the following
  • CPU: AMD Ryzen 5 5600X
  • Motherboard: X570 AORUS ELITE (AMD AM4)
  • RAM: Corsair Vengeance RGB PRO 16GB (2X8GB) DDR4 PC4-25600C16 3200MHZ DUAL CHANNEL KIT - WHITE
  • PSU: Corsair RMX750 white 750W
  • Case: Fractal Define 7 Midi ATX White
I already have a GPU and SSD, at some point in the future I will probably get the following:
  • GPU: Gigabyte GeForce RTX 3060 Ti 8 GB GAMING OC PRO, GBP 420
  • some better cooler than the stock CPU cooler
So I wanted to ask the following:
  • if you were me, would you switch some parts for others ?
  • I plan to use the CPU stock fan at first, is there any issue with this ?
    I will probably switch for something more quiet once I get it running.
  • would I be ok with buying exactly the above, or do I need to add some extras (for fans or cabling) ?
Don't forget there is a white zotac 3070 twin edge GPU out there..... just in case everything needs to be white
That would definitely look nice, I may get something similar if the prices come down a bit when the supply of 30xx cards increase.
