any Technicians around ?
20 Oct 2002
Oxfordshire / Bucks
Got my 570 tommahawk delivered today
and one of the screws on the M2 slot is loose, thought it was just not tightened up, but when i try and tighten it, it just spins
its on the 1st m2 slot , not the 2nd, so i need it
is there anything i can do ?
i'll be using a 2280 m2 drive, so could i move one of the screw slots from the middle to the location i need ?
or has the motherboard got to go back ?
ah the actual heatsink screw. If you can't get that off then you can't install a drive under it.
Can you push down a bit as you unscrew? I don't recall any problems or issues with it.
i can get it off no problem
just received the board, and tested all the screws actually screw tight, this one does not
if i put in my m2 drive, (which is in this pc at the moment) will it be ok or ?
Had to swap them around as the screw wouldn't tighten up
But I now have a major problem
I didn't realise this motherboard takes 8pin and 4pin cpu headers , my PSU has 2x4 only, I'm short by 1 block of 4
Psu isn't that old, its a seasonic Focus Plus 650W. Now my pc is in bits and I can't use it
thanks to my phone to be able to get online and see your reply, otherwise i would have ordered a new PSU
im up and running on AMD now :) Thank You ! :)
3600 @ 4.2 with x570 tommahawk board
running only Corsair Vengeance 3000 RAM (4x4Gb) XMP on (16Gb)
is the RAM ok will i see a huge performance boost if i change these?
