Poll: *** Xbox Series X|S - General Discussion Thread ***
Which will you buy?
  • Series X
    Votes: 537 59.1%
  • Series S
    Votes: 108 11.9%
  • Not interested
    Votes: 239 26.3%
  • Both
    Votes: 25 2.8%
  • Total voters
    909
Maybe it downloads 84gb then reinstalls it over the old version then deletes itself?
Oh 8.4gb makes way more sense!
Just been playing Jedi Fallen Order my my Series S/X consoles and they run the game super smoothly now, a great improvement with the latest patch. Hope more of the older games get patches like this. I'm slowly starting to change my mind about EA.... slowly
Same here was playing it last night after hearing about the update and it seemed to run very well, i need to put more time into this game.
What is fallen order on full graphics? I know performance mode is 1080p 120fp. but my monitor is telling me the full graphics is running 120fps (VRR)
Xbox Series X now features a performance mode with 60FPS and dynamic resolution in the range of 1080p to 1440p, while its normal "non-performance" mode should achieve a post-processing resolution of 4K and a dynamic resolution between 1512p to 2160p.
https://www.ea.com/games/starwars/j...next-gen-optimization-update?isLocalized=true
Yeh must be a glitch. I’ll try it again.
Warzone I see the FPS counter constantly moving. But was steady 120 on Jedi which I didn’t think was right
Have been replaying the mass effect series and currently on 2 again. I purchased some of the DLC (I had most of it originally) but with quick resume on it will not apply the DLC. You need to manually quit the game in the xbox home screen to start a "fresh" play so to speak.
Maybe a small over look it went to connect my speakers.... and no optical cable slot. Can I connect via Bluetooth somehow or are my speakers useless now? I have a set of edifier R1280DB.... problem solved longer cable ran to my TV... did anyone have problems installing valhalla, it asks if I want to upgrade then after I say yes it downloads for a couple minutes then says installation stopped
