auto-optimise is already off and my 2.4 & 5Ghz networks are set to channel 11 and 36 accordingly??
Have you turned it off on both the old and new interfaces? Sadly, you need to turn it off twice.
Hi, just wondering if anyone could recommend the most suitable Ubiquiti access point for my situation please? My current BT Smart hub is ok, apart from 2 rooms where it occasionally loses wifi. Unfortunately working from home & kids home schooling means i now need stable wifi in these rooms.
3 bed terraced house, cat5e cabled back to patch panel with non poe switch, master socket cabled back to patch panel & cable in loft for wap so can easily be mounted on upstairs ceiling pretty centrally (poe injector as no power in loft).
All sky / tv’s / xbox / pc’s are cabled. Wifi devices mixture of 5 iphones (xr & 12), macbook air, hp laptop, a couple of ipads, 3 alexas (all dual 2.4 & 5).
Plusnet fttc, router showing 80Mbps down, 20 up. Speedtest shows approx. 70/16 on wifi in most rooms.
Was hoping 1 wap upstairs would be enough, but can add another downstairs if needed.
thanks
I use a single nano HD mounted to the ceiling upstairs in a 4 bed detached house and I get coverage everywhere.
UAP-HDNano and a UAP-FlexHD downstairs if needed.
Looking for some advice.
Background info
I've been renovating our house for the past 4ish years and have had a bodged non-optimised system of unifi switches and ap's.
Last year I bought the USG Pro 4 and a cloud key. I never got round to setting it up and when the UDM Pro was released I sold the USG and cloud key. This was mostly due to the increased throughput in the UDM Pro.
I've had the UDM pro since September, finally got it out of the box about 2 months ago, updated the firmware, but I haven't put it in place yet.
Having read all the negative stuff about it on the forums (and I also don't think it will do what I need it to) it's heading for eBay shortly.
Before I bought the USG Pro 4, I pickup up some hardware (Supermicro A1SRi-2758F) to build a pfSense box, but I haven't had time, so that's also sitting in a box.
I had intended to use Unifi Protect at one stage, but have now gone back to my original plan of Blue Iris (or maybe Synology Surveillance)/Dahau cameras.
What I need the new solution to do;
- I have 2 internet connections - One 500mbps one (from Virgin) and a backup 80mbps one (from Sky). Any new solution needs to be able to accept dual Wan's, ideally I want load balancing, but at the bare minimum it needs to do failover properly (so another nail the UDM pro's coffin).
- I have a VPN where I wish to setup specific devices to appear from various different countries (i.e. I have several Apple TV boxes, so one is setup for the UK, the other is setup for the US, etc)
- IDS/IPS was one of the selling features of the USG/UDM, so that would be useful (assuming it actually works correctly).
- I would have liked to have kept everything Unifi, so it was one interface to manage everything, but I have come to accept that is an unlikely outcome.
What I believe my options to be;
- pfSense - this was the original plan before the USG. Downside to this is a dated UI (where reporting is achievable but not inbuilt), and historically slow updates/hardware support.
- Untangle - this appears to be the prettier option, but it would also cost £150 a year for the features I want. Is Untange worth paying for compared to the other options?
- OPNSense - this has recently popped up on my radar. My understanding is that it's a fork from pfSense but with a more modern UI and more frequent updates. If that is the case why doesn't this get mentioned more often as a viable alternative to pfSense/Untangle?
- Unifi UXG-Pro - I'd import this from the US EA store. I know this is a stripped back version of the UDM Pro, but they appear to be developing the features for this one that were promised for the UDM Pro. I also prefer the controller not being on this hardware. My issue with this option is will it ever be able to offer a viable alternative to the first 3 options?
Thoughts/opinions at the best way forward?
ah ha, just found that WIFI AI was still turned on (in the new settings) and set to scan at 3am!
Just turned it off!
Muchas gracias.
I have run in to some problems with my Unifi AP and Sky Q setup, hope someone can help - will try to be succinct, having written war and peace on reddit and ubiquiti communities....!
So, I have a UAP-AC-Pro wired to a Netgear (gigabit) switch connected to an Ethernet port on the Sky Q Hub (newer SR203 model) and a UAP-AC-LR connected (via gigabit powerline) to the UAP-AC-Pro. These devices handle all wireless connectivity in the home, except for the Q devices, which remain connected to the Sky Q hubs default wireless. I also have a CloudKey Plus (Gen2) as Unifi controller, connected directly via Ethernet to the Sky Q hub. This all works brilliantly, strong and stable wireless throughout the circa. 200m2 house.
However, having had an electrician in for a couple of days doing work such as replacing the consumer unit caused us to need to power off for a while, on a couple of occasions. On each occasion, when firing everything back up, I had massive issues getting *internet* connectivity on pretty much any device. No webpages work, many devices report "wireless connection has no internet" and so on. So, logged on to the Sky Q hub's native wireless, and all works fine...... power-cycled ubiquiti kit several times, rebooted Sky router, tried all sorts and the problems seem to last. Only after close to 2hrs, having literally shut everything down and slowly, sequentially firing devices up was I able to regain proper working environment.
This happened on day one of works, made me sad. Day 2, yesterday, with trepidation.....and same problem. Literally took a couple of hours, rebooting of devices and so on before finally getting a semblance of functionality back.
Any thoughts greatly received - the ubiquiti kit is brilliant, but it is tooooo complicated for me, I worry. I really want to persevere, but pressure is building to go for something a little more consumer friendly that 'just works'....Please help me keep the kit![]()
Thanks for the replySo, if I can clarify, you have a SkyQ Hub -> Netgear Switch -> UAP-AC-Pro (up to here this will just boot up every time. No problem. Even without a controller running this will boot up.)
SkyQ Hub -> Netgear Switch -> UAP-AC-Pro Passthrough Port-> Powerline Adapters -> UAP-AC-LR
I can see why it might not even work at all, and I think you might be better switching meshing on and taking the powerlines off because meshing will only kill half your speed whereas wired uplink reduces the speed on both the -Pro and -LR and then the powerlines will further cripple the traffic back to Pro from the LR.
So I would try taking the powerlines off and frankly, the rest of it should just boot up. It might take a few minutes to figure out what's going on, but it should just boot up. We had a complete power cut here last night and the Gen2+ cloud key took everything offline tidily and then the UPS switched everything off nicely. And then when the power came back on I flicked the switch and it all powered straight back up. No intervention from me at all. And that's 3 switches, 5 access points, a Cloud Key and and Untangle router, plus the NAS units and the NVRs. So I think it has to be the powerlines and the order everything comes fully awake. So the Sky hub usually boots up fairly quickly. The access points are probably booting up last on their PoE injectors. And then they'll be trying to establish comms with the router through all that bodgery you've got in the way.
I'd try it with out the -LR and the powerlines. That should definitely work no problem. Then mesh in the -LR and I think it will be fine. Powerlines don't seem a very good idea to me in this use case.
