MSI Trio 3090 water cooler purchase list
15 Jan 2021
Hello all.
Be gentle, I am new to building my own watercooling setup.
I currently have my CPU watercooled, and I am not looking to incorporate that into my setup ( or have I overlooked something obvious here ? ) Its a corsair closed loop system for reference.
I have created a parts list , but would like someone to cast their eye over it to validate if I have specced it correctly , or missed anything obvious.
I cannot fit a larger rad in my case.
My criteria is to keep the volume down, I wont under volt or anything though .
I assume with this parts list my expensive 3090 wont end up as a ball of molten silicon?
Any advice is really welcomed
OP
15 Jan 2021
Smashing. Thanks.
I assume I would need a pair? One for close to the pump , and one on the opposite side close to the rad? Can drain in a controlled fashion then?
Man of Honour
23 Mar 2011
West Side
Smashing. Thanks.
Not really just need one usually at the lowest point, so you driain then turn off move the case about so the leftover water moves to the lowest point and drain again.
3 Feb 2009
You might be pushing the cooling capacity of a 240 slimline rad if you've got a 3090 - ~350W of heat before you start oc'ing.
What's your case? I would definitely want more rad than that to ensure I wasn't seeing thermal throttling on the card.
OP
15 Jan 2021
Hi , I have a Obsidian Black GameMax PC Gaming Case. It wont take much more than a 240mm rad. I guess if I got some high CFM fans to dissipate the heat it could work?
I based it on this : https://youtu.be/0WVpW497vTU?t=215
3 Feb 2009
I haven't watched the whole video but the temps quoted were based on a loop outside a case. You're going to see a big difference in a case that cramped. Also something to consider (apologies if it's covered at the start of the video) is the fan speeds, if you want anything that isn't ear-destroyingly loud then over-provisioning on rad capacity is the best way to do it.
I can't find any specs easily accessible but looking at some pictures of the case internals you might be able to get a second 240 or even 360 rad in the front. If you're desperate to keep the case I would bust out the ruler and start measuring things like RAM clearance for potential thicker rads and space for something in the front.
OP
15 Jan 2021
I have the ruler back out again!
I have at most a 300mm drop to work with. The actual space is more like 340-350mm but not deep enough to accommodate fans.
I dont really want to change cases if possible.
3 Feb 2009
I assume you mean 30mm not 300mm? If you've got a 30cm gap then we're a little beyond caring what rad you use :p.
Seriously though, are you talking about 30mm total gap or 30mm after accounting for your 25mm worth of fan depth? If you want to stick with EK then you probably wouldn't squeeze the next size up (PE @ 38mm height) either way.
With that little rad you're going to be working with less dissipation capacity than the stock cooling solution and therefore probably running your fans faster/louder as a result.
OP
15 Jan 2021
Ah , my mistake and I dont think I was clear enough.
The front has a 300mm drop 125mm width and ~30mm depth to accommodate a rad. I dont know if these images may help?
Front ( with cover removed ) 2*120mm fans there
Top, you can just make out 1*120mm fan there
Side ( Corsair H80i twin fan and rad at the top front of the case here )
Minimal scope for a top large rad fitted on the case top due to the RAM location
Profile image of case.
3 Feb 2009
Ok, well it looks like that case is going to be pretty tough to work with but I think you have some options if you're desperate to keep it and don't mind stretching the brief a little.
With the cooler off that gpu you're going to have plenty of room for a fat boy 240 at the front and if you're not opposed to having something sit a little proud of the case then you could have the fans/rad out of the top of the case. Assuming you don't mind a little light modding you could route the tubes out of the case and into a rad on top of it and keep the top fans inside and exhausting. Otherwise, if the space permits the routing, you could have the rad mounted inside (something thin enough to maintain clearance from the memory etc) and the fans to cool it mounted externally.
OP
15 Jan 2021
I appreciate your input , again!
I *think* this is my preference. 4 fans in a push pull combo across a fat rad.
I think this is my second choice route. I could easily route the pipework vertically and dremel in a couple of holes to mount a large rad on the top with some fans. Mad max style.
I reckon if I was carful with the curves I could even route out of the back and then vertically. Would look neater. However, as you maybe able to tell, function is over form in this case!
I now need to find somewhere that has a MSI Trio 3090 water block in stock . OC dont appear to ..
OP
15 Jan 2021
I found one on a site , but after a quick scan of the spec I am not convinced its the right product. I think there is something unique about the MSI trio 3090 as it has a specific waterblock for it ..
