- 23 Nov 2009
- North Leicestershire
Quick background 2.0 TDCI purchased at 100k and done 80k in 4/5 years since I purchased its had, new injectors,turbo,dmf and clutch and a few other cheaper bits.
Recently within the last few weeks its cutting out without warning it will either start straight back up or take anything from 10 seconds to 20 minutes to get going again. Its had a leak of test done and injectors are good, fuel filter been changed. Been on ford diagnostics which shows nothing wrong at all prior to the cut(basically drove around until it cut out)
At a complete loss now, 3 garages have said they wouldn't know where to start and I've already done/had done the tests they would do.
I'm hoping with it being a 15 year old car and being many members on here someone might have encountered a similar issue which could possibly give me a starting point to look at myself.
Bit of a crapper as its the daily driver for work. Not really keen on putting 400/500 down for a run around to potentially be in the same position again(my track history with cheap motors isn't good)
Long post i know thanks in advance
