For background I'm building a new PC which means I have the following components:-
1 New MSI X570 tomahawk motherboard
1 second hand 2080 ti graphics card (new to me)
1 second hand 3800X ryzen processor (new to me)
case is a new Lian li o11 and the power supply is a corsair SF750 that I have from a previous build last year.
2 existing NVME drives
2 existing ddr4 memory sticks
1 existing ryzen 3600 processor
1 existing 1080 graphics card
The existing items I've had for ages and not had problem with.
To begin with I built the system and tried to boot into an existing windows installation - that failed. After 3 attempted boots I created a fresh install of windows on the other nvme drive and wiped the first.
The installation worked until Windows tried to install the nvidia when it crashed.
Thinking it was a graphics card issue I replaced the 2080 with the 1080 and - same issue (works until you start an geforce driver install then windows reboots 20% of the way through)
To rule out the memory - I've tried all 3 variations and all have the same issue (works until you start a driver install then windows reboots 20% of the way through)
To rule out the cpu I swapped it and its the same again (windows works until you install the nvidia driver then reboots 20% of the way through installation).
I've also updated all the drivers (except the graphics card) and the bios but I'm still getting the same issue.
Am I correct in saying that there is something wrong with the motherboard as I cannot think of anything else to test (and yes I would have returned it ages ago except trying to find a decent motherboard at the moment is a complete nightmare).
