Yeah we are finally starting to see some uw with 1600 height and some 2160 height screens. It was what kept me away from UW for so long, the appalling low ppi of them
New helmet.
Never heard of Nolan. They do some quite snazzy designs.
I had to improvise as there wasn't a speaker that I liked.
They're stools without the top.
https://www.amazon.co.uk/dp/B01BQCCNFU/ref=cm_sw_r_cp_apa_fabc_o9tbGb2QY9SHT?_encoding=UTF8&psc=1
much betterIn December I bought the flat I've been renting for the past few years, first job on my list was to replace the terrible hob and dying oven.
Old:
New:
Really pleased with both, they make a huge difference to how the kitchen looks.
Isn't the bigger win that you now have what looks like induction instead of hotplates. Induction is amazing. If it isn't induction, why not?
Yep it's induction. Only tried boiling a pan of water so far to make sure it works but it did it in no time, and being able to turn off the heat instantly is a bonus too. The old one took ages to heat up and ages to cool down again. I need to get some new frying pans now as my current ones are aluminium.
The oven is pyrolytic too so that should make cleaning much easier.
) worth of case fans (and a hub) later, as well as a new AIO. Just need to go and finish off the cable tidyingVery pretty thing Steedie. Where's the PSU?
It's a dual chamber case, it's on the reverse side where there are two removable caddy's for hot swap HDDs.Very pretty thing Steedie. Where's the PSU?
