I thought you were RMAing your board?
If the WHEA unrecoverable errors continue after the BIOS update that I expect, I will.
Edit: ignore.
Yeah I made a dumb mistake the power switch wasn’t in properlyIs it alive now?
. The lack of leds threw me off, thought the motherboard wasn’t getting power!Stupid question but can I get the seller to run the bios update for me? for example if I buy from OC is there an option to do this step and test the motherboard? Im building my first pc and this is one of the steps im dreading trying to do myself (just got my 5800x and the x570 Tomahawk looks like it would be a decent motherboard to pair it with)
. And I guess there's nowhere else I can get the official drivers and updates... Even if I fired up an old laptop with a CD drive all the stuff on the CD would probably be out of date.Ah Maybe it was the 14-15-15-35 that was the problem, isnt the ram meant to run at 18-22-22-42? Profile 1 and 2 are identical so why have 2 profiles the same?
If I do that again I am worried about bricking it again. Should I OC the CPU first?
