I thought you were RMAing your board?
If the WHEA unrecoverable errors continue after the BIOS update that I expect, I will.
Edit: ignore.
Yeah I made a dumb mistake the power switch wasn’t in properlyIs it alive now?
Stupid question but can I get the seller to run the bios update for me? for example if I buy from OC is there an option to do this step and test the motherboard? Im building my first pc and this is one of the steps im dreading trying to do myself (just got my 5800x and the x570 Tomahawk looks like it would be a decent motherboard to pair it with)
Ah Maybe it was the 14-15-15-35 that was the problem, isnt the ram meant to run at 18-22-22-42? Profile 1 and 2 are identical so why have 2 profiles the same?
If I do that again I am worried about bricking it again. Should I OC the CPU first?
