Hey,
I hope someone can offer some advice?
I am on the market for a new router. I’m currently using the Virgin hub 3 but the wifi isn’t great. There is one room in my house that only get a weak signal. Basically I'm looking for a stand alone router, I don’t want to set up a mesh network network at the moment. I have seen that on some routers you can buy a second ones and set it up as an access point if you want to at a later date. What I’m really looking for is a router with really good range and obviously good speeds. I’m not very technical so I don’t want to have to buy a router that you have to fiddle with hundreds of setting to make work to its best. I’ve watched loads of review on YouTube and stuff but you never know who to trust as loads of them say Netgear but I’ve only ever known people to have had problems with them and all the Amazon review say how unreliable they are. Other views are raving about the ASUS Ax86? I was looking at maybe getting the ASUS Ax86 but I’m worried it won’t be any improvement over the ASUS ac86 which I made the mistake of purchasing last year only to find out ac86 is on the same performance level as the Virgin Hub 3 and doesn’t offer any advantages in terms of speed or range I’ve it.
Any recommendations on a super solid router would be welcome. I don’t want complicated to set up either! Lol!
Thank you for reading.
Oh my budget is up to £300.
