- 19 Jan 2021
LLC on auto. I am down to 1.20ghz with a 15 minute realbench run stressing 16gb ram out of 32gb.
What I am finding is that whatever vcore I set in bios it’s is always more under load. Eg. Vcore 1.220 becomes 1.230 under load. Is that normal or even right?
I thought that if I could run Realbench at 1.200vcore for 6 hours then I would be fine. What I have been reading is that the system may crash when gaming even if stable at 1.2vcore under load with Realbench.
The main reason for the under volt was to lower heat and power draw. 1.310 stock is just dumb and Realbench and Prime95 (won’t use it again now) just hammered the system at stock. 100c on some cores in under 10 seconds even with an aggressive fan curve and -2 avx offset.
m
m
