3060Ti Power Dongle
It’s obviously done to save space on the PCB. Not only the connector is much smaller than 2 8pin connectors but it’s also mounted vertically.
Which is all well and good, but now there are half wired 12pin connectors cables in circulation, which will not work with the cards that require all 12 pins wired.
I love the 12 pin connector, it is better than the current standard, it's smaller and you get more pins.
Fair enough. Any difference in performance or just aesthetics ?
I took the back plate of mine and tested the pins as I made my own connector, all 6 of the ground pins are connect to the circuit but only 3 of the 6 positive pins are connected.
