- 16 Jan 2021
Just received my Ryzen 5950x and B550-E combo and I get code 00. When psu power is on the motherboard lights up but when I press power on the case it goes straight to code 00.
I have tested this everything installed and I have also tested this bare with only cpu and PSU but still get the same code.
I have also tested with a different power supply but still code 00.
I also tried updating the BIOS using the BIOS FlashBack to latest build "SB550EG". Was able to update the BIOS I believe. Motherboard show 00 while doing BIOS flashback.
I have also tried taking BIOS battery out and waiting a few mins... for what that was worth.
Had a look at the CPU pins and they all look perfect, no bent pins. The socket also appeared to be clean.
Anybody else having this issue?
