It actually looks quite good to be honest easy to fit aswell was thinking of changing fans myself to Rgb but going to see if I can get a good fan curve first and have a play about to see what the best setting is for it doyll give me some sound advice which I'm going to try the pump is quiet so just the fan curve to sort
let me know how it goes - anxious to get my build going ... finally
Im sitting here deciding on the pure loop 360, phanteks 360, corsair caprillex (spelling) 360 (expensive thou but you get 3 good rgb fans and the commander core is it, or some other loop.
I want something that will be less noisy also
