Phantek aio
The other aio which has a quiet pump is tbe asus strix and that can be had with rgb fans aswell but believe fans are loud again
Ahh ok good to know, I don't care as much about the fans, eventually I'll try to match my fans throughout my case, ie 3 front 3 top 1 rear but don't know which ones yet... Fans I can do something about the pump I can't.
I don't remember if I asked you, how do you control the pump speed of the phanteks in the mb bios? Also the pump rgb its hooked to where and controlled by?
I went with the new corsair 5000x case so can use icue for my case fans, not sure about a phanteks aio pump rgb.
The pump is connected to the cpu header i left that on auto i did mess about with it in bios but put it back on auto and let it do its thing havnt heard it at all
The rgb goes straight to motherboard 5v rgb header
Thanks for that.
Looks like there is a dedicated thread on the corsair forums 6 pages long talking about the pump noise... Too bad.
Again I don't think there was one review that mentioned this. But lots of people are complaining. And corsair already said due to design, they can't lower the pump speed.
Thanks for that.
Yeh that was one of the reasons what put me off was the noise from pump id read about it to be honest it was between asus and phantek for me phantek has a good customer support as for asus well wont go there also phantek has 6 yr warranty ssus is 5 same as corsair so i figured that into my decision also and was slightly cheaper but that was just a bonus the fitting of it was simple even a kid could have done it
I assume CPU header is controlling pump speed. So what is pump rpm? Assuming it change speed dependent on CPU temp what is it's speed range?
Yes it controlled by cpu header i just looked at hwmonitor it says its running at 1214 rpmmin and max is 2020 rpm does that sound right thanks
