Commander Pro QL Fans
I think I am right in saying that the the commander pro has two RGB outputs on it. However you may need more than that so you will either need a hub or a Lighting Node Core which have six RGB outputs, which are usually sold as part of the QL lighting kit. The commander pro and lighting node core are sold separately since you may not need both.
