Man of Honour
- 21 Nov 2004
Bulldog Gear Mammoth lite rack arrived. Really pleased with the final result - I wasn’t as pleased when it arrived mid meeting this morning rather than the agreed afternoon slot. Pull-up bar just about fits when set to the right height. I managed to neatly adjust the raised deadlift platform down to 20mm where the feet extend into it. The feet aren’t as wide or long as I measured, so the impact on the deadlift platform is minimal.
Tried out the pull-up bar, it’s absolutely solid, not even a wobble. I think I’ve worked out whether the J-pegs and catchers need to go for each workout. Will leave my unused plates on the base to stabilise it even more.
Edit: this rack is amazing. @LiE you were right, the pull up bar adds a lot of stability. I didn’t expect it to be so heavy and well built, bulldog sure make a quality product. Hopefully I won’t need to buy anything else for a while.
Edit 2: it’s great to not have to walk out as far unlike my previous rack that had the feet in the way. It also feels safer if I need to bail. I’ve set the uprights one hole back from the recommended position to give me a fraction more space and to add a fraction more stability. Not even the slightest wobble.
