- 27 Dec 2006
- Northampton
Acquired a Google Nest hub and looking to make it look cleaner than just placing it on a desk or table.
I want to primarily use it to control thermostat on the 1st floor as my main one is downstairs and also to view my CCTV on the outside of my house.
I want put it into my wall if possible and use one of these brackets.
https://www.amazon.co.uk/Mount-Geni...07ZP8GW16/ref=cm_cr_arp_d_product_top?ie=UTF8
As you can see its quite recessed into the wall but if I end up going down this route, what suggestions do you have to power it? There is an adapter to use a POE but getting access to it or to hide it is another matter. I think using a wall plug is best but suggestions how to make it look as clean?
