it is instinctive, especially for upstairs light where you might turn it on before going upstairs, unless, you have a motion detector facing down stairs.
Does that rely on having an active hub that speaks to the bulb after the power-off, or, it is functionality(eprom) in the newer BT/bulbs
.... ie. I shouldn'y buy old bulbs.
I was under the impression it needed the bridge, so new bulbs (BT) would still work, they would just pick up their power on instruction from the bridge.
Tradfri bulbs don't support this from the Hue bridge. You might get it to overlap with the Tradfri hub to get it to return to previous status, but frankly that would be a waste of extra hardware/power for the very rare occasion. Plus with a centrally controlled smart hub, there's much easier options.
it does become that lifestyle change to remember not to manually flick the switch off but its the convenience of walking out of a room and the door has the light switch right next to it. It takes longer to find your phone to open the app and then scroll to the light and switch it up.
I've been reading up the options I have to have both functionality of the light switch on the wall and get it functioning on the app.
It's even better than that. One of the best setups i've got is a contact sensor on my front door, so as soon as the door opens, the hallway light switches on. There's no faffing around with voice commands, or waving at motion sensors (Hue motion sensors are **** btw), the light just comes straight on before i can even open it fully to walk through.
