hi another idea! have you tried seeing if your bios is upto date, if not try flashing.g the latest? I know I'm clutching at straws! just an ideaI have 4 nzxt aer rgb fans and the case is the nzxt h510. My airflow is surprisingly good considering the case and the gpu and cpu temps are really good. Im using two 32 inch monitors ones Dispaly Port and ones HDMI. I have tried the other outputs on the GPU and they all give the same result. It truly is bizarre. My guess is that the drivers are not working properly or my cpu is bottlenecking so much my GPU performance is getting cut. However, I have done a DDU and have done a clean install of the drivers. Both of my monitors have their max refresh rate selected
have you tried just running one monitor on display port maybe a conflict between dp and hdmi? this is just a guess I know my evga1080ti doesn't like hdmi as I have problems whenever I've tried to run hdmi, I'll get my coat...
