Only 48Gb out of 64Gb showing?
26 Jan 2010
Hi Guys
I have 8 sticks of 8gb 3000Mhz Corsair memory sticks
I always used 4 sticks 8x4=32
I picked up a cheap set of identical memory sticks, so I installed
But Only 48Gb shows instead of 64gb
I have a Asus Strix X299 Chipset on a 48 Lane CPU, my mobo supports up to 128gb
So why has 2 sticks disappeared?
Only 6 sticks registering
Ideas?
Have you tried reseating the RAM? How is the RAM arranged? Check the manual. Have you tried turning off XMP?
thats weird
its should be plug n play, all my sticks are 8gb each all at 3000mhz, checked BIOS and everything at auto settings
IQUE shows 8 sticks for the led stuff so i should think its all seated correctly thought ill have a check now
My CPU is a i9 48 lane cpu so its more than enough to handle 8 sticks
he he he
i dont know what i did but i did 3 things and somthing fixed it
I identified the 2 missing modules and took them off and reseated, though this time i heard a click
then i enabled XMP
then i enabled Asus smart overclock, OC the ram by 33% and CPU by 25%
Then i restarted and now, now the 64gb is detected
so what fixed it i dont know but im gonna leave it for a while, then i disable xmp and the auto overclock to see what happens
Definitely not the OC step :D
you do not overclock RAM and your CPU while trying to troubleshoot your missing RAM :D :D
I vote for reseating as a reason for a fix
Hi Guys
So why has 2 stics disappeared?
Ideas?
What operating system?
