Cat 8 cable?
My only idea was that it is like comparing a 2 lane motorway with a 5 lane motorway, you cant go any faster than 70mph but on the 5 lane you can get MORE there at that speed ?
so which cable is this that gives you more than the 4 pairs of regular ethernet?
The kenable cat6 I have may be better than the above "cheap and cheerful" some people talk of. The Kenable I have has an internal spline, internal pull thread and is black outdoor UV rated. It's quite hard to bend at a tight radius or you can damage the internal spline. It's solid copper core and apparently 23awg. It's about £45 for 100m.
looking at the excel brand cable cat6, i noticed in the pics it doesnt have that crosstalk divider spline going down the middle. why is excel rated as good quality then?
All of the Cat6 Excel cable I've ever handled over many years has had the divider. If you look on their website every type of Cat6 they sell has the divider.
What are you looking at? It isn't unusual for resellers to mix up the pictures for all sorts of products.
I can assure it does. It's much bigger and stiffer (ooh er! Missus!) than the one in the Kenable equivalent and the outer sheath is thicker as well.
Anyone had a real world situation where shielded cable was of benefit?
YouTube vids show the difference when cables run near ac motors but dunno if anyone has had in house experience where shielded was needed.
As per WJA96's comment, I can also confirm that it has the plastic divider as that's the cable I used in this house and I still have some of it in a box in the loft. Excel Networking would be my own personal choice for installs from the cable to the patch pannels etc...
There is also little to no requirement for shielded cable in a residental property.
The challenge is ‘how would you know?’ And simply put very, very few people are equipped to measure Electromagnetic radiation. So if it was working really well, or it’s completely pointless, we’ll probably never know.
This guy here demonstrated how easy crosstalk happens if the cables are next to each other:
https://youtu.be/SguxCeOFPQk
Thats the video that got me thinking
And yet the real world says that demo is some kind of special case. I’m sure he got the worst case unshielded cable he could find to sell his expensive cable against.
And in any case, anyone ‘proper’ running high quality (4:4:4/60Hz) 4K over HDMI converters is using optical fibre anyway.
thats what i dont get, iv seen loads of cables in trunks together and none of them shielded so dont get how the guy in the video was able to demonstrate that with just 2 cables
Just looking at replacing the ethernet cables in my home was looking at Kenable Cat8 but there all flat cables, thought they were a reputable place to buy cables but I've also read flat cable is just a gimmick. Any help here would be appreciated.
Just looking at replacing the ethernet babies in my home was looking at Kenable Catherine but there all flat cables, thought they were a reputable place to buy cables but I've also read flat cable is just a gimmick. Any help here would be appreciated.
Replacing what cables for what reason?
You'd have to try very hard to buy a standard Cat5e or Cat6 cable that didn't work.
The problem with flat cables is avoiding the one's that are complete junk. If you don't need your cables to be flat then they would be a gimmick.
I'm assuming there was some autocorrect goodness in your post?
I bought some junk Cat7 cables a long time ago from amazon and just looking to replace them for some decent, normal cables. I assumed all flat cables were junk and was suprised to see them on Kenable that's all.
Autocorrect did me dirty there, yikes.
Don’t use flat cable. A friend tried using it in to a patch panel recently to make it look neat in places, but it just wouldn’t recognise it at all when patched in.
I gave him my spare Cat6 reel (from Kenable actually) and what do you know it worked first time...
Are the 'junk' cables you have causing problems? If not replacing them is pretty pointless. They don't need to be 'Cat7', just good enough for the speeds you're running.
There are two main reasons why flat cables can be 'junk'
  • They don't use twisted pairs
  • They use undersized conductors
It's quite possible you could get a flat cable that doesn't have either of those problems and would work just fine for a limited distance (and all stranded patch cables are only good for a limited distance). Unfortunately, a cable like that wouldn't be as thin as you'd really like a flat cable to be. You also can't usually tell how the cable is constructed without chopping one up.
