Chaps, I think you are all missing the point. The 330e is designed to essentially tick a company car tax box. No recipient of a company car with a fuel card is going to pay leccy to plug their 330e in. The gimmick is simply there to avoid tax. And then the point is that it isn't exactly an efficient petrol car.
Again, you're missing the point. Almost no private owner is doing a business case on this car because of its 30 mile EV range (more like 14-22 in the US). It is all because of the tax incentives versus comparable cars, far outweighing the fuel saving. Especially once you factor an electric charger install.It’s a global car, don’t confuse your UK centric view. It’s to meet CO2 commitments/ legislation not play UK BIK fiddles.
Not efficient petrol engine? Exactly clue is in the hybrid name.
??? You don't consider servicing cost, mpg, purchase price, depreciation when you buy a car? maybe the word business case is a little too sophisticated but it isn't hard to grasp the key concept.If I’m missing the point then atleast I’m aiming...
since when did private buyers do “business cases” anyway
Silent driving and instant torque drives better than your average 2 litreDon't know if I would. Remember to plug in every day and go to the effort of doing so, to save 3 litres of petrol a day?
M Sport Pro with tech pack.
To try and answer your questions, and avoid the bickering people seem to have resorted to I can say that the 330e is a very nice vehicle overall.
Can I ask what your typical daily mileage covered is, and do you do lots of long runs or many short runs?
The nature of this car is that with the plug-in part, if you use it as intended, then you can save an awful lot of fuel and quite a sum of money (if paying out of your own pocket), you can achieve between 20-30 miles of range on the battery mode only, as long as you aren't flooring it away from roundabouts and lights at every opportunity, and aren't doing 80mph on the motorway for the most of the journey.
The charging is easy enough, and given the relatively small battery you can use a normal 3-pin to Type-2 EVSE charger, or get a proper Type-2 installed at your home, assuming you have off-street parking you should also be eligible for a grant. Obviously the good thing about getting a charger now is that you will have it for your next vehicle ,which has a good chance of being a full BEV.
The fuel economy is lacking on long runs, which is obviously annoying if you do this a lot of the time and you should probably avoid this car if that is the case, but if you commute say 50 miles and you can do 30 of that using cheap 5ppkWh electricity, then it would still beat an efficient diesel car without issue on running costs.
It’s simply cos the company car clowns on fuel cards get free fuel and plugging in actually costs money!
that said planning where to park at home can be quite tough to think about on your way home...
Could you expand on that please?Btw M Sport Pro is horrible, avoid it.
