1080p 144hz build or a laptop?!
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
Looking to potentially put together a modest build for 1080p 144hz gaming, mostly fast paced games. It all really depends on whether I can manage to get a 3060 when they are released.
Here's what I'm thinking.
CPU: Intel Core i5-10600K 4.1 GHz 6-Core Processor £209.65
CPU Cooler: ARCTIC Freezer 34 eSports CPU Cooler £29.54
Motherboard: MSI Z490-A PRO ATX LGA1200 Motherboard £139.49
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory £74.20
Storage: Western Digital Blue 500 GB M.2-2280 Solid State Drive £49.94
Video Card: RTX 3060 ~£330.00
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case £58.99
Power Supply: SeaSonic CORE GM 650 W 80+ Gold Certified Semi-modular ATX Power Supply £75.46
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan £8.69
Monitor: Pixio PX248 Prime 24.0" 1920x1080 144 Hz Monitor £169.99
Total: £1163.33
Desk space is limited so I'll spend £50-60 adding a 60% keyboard and I'll need to wall mount the monitor. I already have a mouse. So total looks to be about £1200.
The other consideration is a gaming laptop as it similar ballpark price and will be better in terms of space constraints.
My basket at Overclockers UK:
Total: £1,299.95 (includes shipping: £0.00)​
Thoughts?
They both have pro's and con's its really what suits your needs and the obvious availability. Personally i prefer gaming on a bigger screen than a laptop
Depends how you will use it. If you need mobility, than laptop.
If you will game in your room 99% than desktop.
I did both, but prefer the desktop. More comfy for me and enjoyment.
It might sound a lot but 500gb wont last you long when there are 50gb game installs. I would chuck another 500gb drive in as a gaming drive or find a 1tb drive too.
I only tend to have a couple games installed at a time, I can always redownload on my 900Mbps line.
I'm considering of going for the 5600x vs the 10600K. It's about £50 difference when you factor in decent motherboards.
OK so budget went out the window some what. Went with:
MSI MAG B550M MORTAR
5600X
Gigabyte GeForce RTX 3070 8GB AORUS MASTER
Dell S2721DGFA
Phanteks P300A
650W Seasonic Core Gold
Kingston HyperX Fury 16GB (2x8GB) DDR4 PC4-28800C17 3600MHz
WD Blue SN550 500GB NVME M.2 2280 PCIe Gen3
Just need a keyboard now and no where has stock of the NH-D15 Chromax..
I have a Logitech G513 and is very comfy. I love it, but if you prefer other brands, you can have a look on Corsair Keyboards.
I really want a wireless gaming keyboard but it’s a very small market.
Edit:
Then I see the Asus ROG falchion 65%... need to look into this more.
For those who are interested here is the final build I have coming. Some parts have arrived already.
Motherboard: MSI MAG B550M MORTAR
CPU: AMD 5600X
GPU: Gigabyte GeForce RTX 3070 8GB AORUS MASTER
Monitor: Dell S2721DGFA
Case: Phanteks Eclipse P360 Air Mid Tower Case Tempered Glass DRGB- Glacier White
PSU: 650W Seasonic Core Gold
Memory: Corsair Vengeance LPX Black 32GB (2x16GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Dual Kit
Storage: WD Blue SN550 1TB NVME M.2 2280 PCIe Gen3 SSD
CPU Cooler: Noctua NH-D15 Chromax.black
CPU: AMD 5600X
The noctua nhd15 wont fit its 165mm tall and the case supports max cooler hieght of 160mm. .
Agreed, I have one too, wrist support is brill but software is a bit **** so I can't customise game profile lights - I use X not CTL in csgo for 'duck' and I can't change that in newer GHUB or older LGS..
Get the laptop.
I got an rtx 3070 laptop, one with that delivered 150/200watt to the GPU and it was 144hz panel, Intel.
Good performance and it was very compact.
It was overpriced , but was good
Get the laptop.
I've already built a desktop. I did like the idea of a laptop but I don't need the portability. A laptop is good if you need to move around, otherwise I'd rather run juicy hardware and cool is really well. I can also drop in new hardware as I want.
I'm going to try some other fans out ( Arctic Bionix P120 A-RGB ) as the Phanteks SK120 have a pretty rubbish sound profile at low RPM due to motor noise. I will trial the Arctic fans in the front to see how I get on.
Here's some photos of the new machine.
Very tidy setup. I really like the look of this. Well done
