Can't get GPU to work
18 Feb 2021
I've just built a new rig and while I wait for 3080s to get back in stock I have put in a borrowed 1080 founders edition.
I have a ROG STRIX Z490-F mobo and i9 10900K.
I can't get the 1080 to work. In Windows 10 it says "
This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other devices on this system."
I can't see anything else that it is conflicting with. I have an M.2 in the M.2.1 slot in PCIe mode but this should not affect my card according to the mobo manual. It's only SATA that gets knocked off if I use SATA in the M.2.2 slot.
Tried DDU with drivers ect but no luck. It actually gives me the code 12 error above before I even install the Nvidia drivers.
Any ideas?
6 Mar 2012
South West
Quick google and hope this helps
The “This device cannot find enough free that it can use (Code 12)” problem is displayed within the device’s properties windows in the Device status box. That error is usually a hardware conflict which arises when two devices are assigned the same I/O port but there are other culprits as well.
https://uninstallguides.freeforums.net/thread/1038/fix-device-find-free-resources
OP
18 Feb 2021
Thanks I did find that page but that video isn't the best thing to follow. I don't know why they just didn't speak over it.
Pull the M2 drive out and try an SSD?
It maybe a faulty board, or a damaged pin array under the CPU limiting PCI-E lanes.
I've just pulled my m.2 and installed windows on my SSD. Still the same so it's not the m.2 conflicting. Need to try another card to test I think.
18 Jul 2009
Tividale, West Midlands
Damaged motherboard pins under the CPU? Thermal paste leaked onto them? The CPU controls PCI-E bus.
OP
18 Feb 2021
I actually managed to get the GPU to run and it drove my 3rd monitor and the desktop spread over as it should. I did it by using hardware troubleshooter but when I rebooted I got the same error. I doubt I would have been able to do this if the CPU pins are physically damaged?
