Ok so where it says FIXED VOLTAGE type in 1.250v. Best to always start high and work down. Then save and exit.
OK. I will try that. give me 5 and i'll be back
No worries, it would be handy if you had CPU-Z installed, have you got it?OK. I will try that. give me 5 and i'll be back![]()
No, just 1.250Silly questiondo I have to add the v after i enter 1.250
Ok, is this stable? Core speed should fluctuate slightly around 4800mhz.I notice that core speed keeps changing values, maybe this is normal ?
Fine, so long as boosting to 4.8 under load thats good.
Anyhow, you have dropped voltage from 1.33v so temps will be better now. You 'should' be able to drop voltage to 1.200v maybe less, although each 10850k is different.
Ok all looking good!Ok test and see if all is OK,
Thank you so much and for staying with me all this time
If you dont mind, I will encode the same bit of footage again for Handbrake and I will use core Temp again and post back here for you to see if there is a difference from the first time I posted the results![]()
Looks better, weren't you getting up to 80c before?
Yes is the answer, but it will be tral and error and take some time. If you are happy with these temps just stick with 4.8 @ 1.250v, if not yes, save this profile and lower voltage to say 1.220v for even lower temps and so on, BUT make sure you are 100% stable with each lowering of volts. I always write it downYes, I think i was or close to it, I souldnt be asking after all the help you give me, I think i can save this profile or setting in the bios.
Can I improve on the settings that you give me? If so, what would you suggest changing?
Thank you.
