New gaming PC for £600 max
10 Aug 2003
London
My 14 year old nephew is wanting a new gaming PC will also be used for school work too. I have not built a new PC for many years,so could do with some advice. I have an old ATX case, that I could give him to save some cash, if it can still be used with the newer motherboards and he wants it. He already has screen but wants a second 24" screen, likewise has keyboard and mouse already. Is AMD the way to go for the best bang for the buck these days?
What would be the best bang for the buck spec including the following CPU, Mainboard, GPU, Memory, Storage, PSU, Case and OS please?
Thanks in advance
Intel is now bang for buck.
Right now is not a good time for budget gaming builds.
A 1050 Ti now costs £199.99, that card came out years ago.
I suggest waiting. Unless you can pick up a bargain graphics card 2nd hand.
You can't do it these days. Have a look at gpu pricing and availibility. AMD APU may be a good shout, if they aren't crazy prices?
Are GPU prices likely to drop in about a months time??
TBH Probably not. Chinese new year generally means an almost full shutdown of manufacturing across China for as long as a month in some areas. And with TSMC being tasked to produce silicon wafers for the automotive sector actual manufacturing capacity of the chips is severely curtailed. In all honesty this shortage could last throughout the summer.
Budget increased to £800/850 now. Is intel and their 11th generation still better value than AMD? How well would the integrated GPU work for Fortnite to tide him over till graphics card drop in price/supply increases?
If you have a 11500 or higher, then it's doable at 1080p (the 11400 has less EUs), assuming decent memory that is running in dual channel mode. There's quite a few videos on youtube to show you what it's like.
Still wouldn't bother buying anything at the moment. I put together a £600 machine at Christmas with all new parts apart from a ASUS Strix RX 580GB. Had a 10400f, B460M Mortar, 16GB RGB RAM, 1TB SN550 nvme, Case with 3 RGB fans, 650w psu.
You're better waiting a while longer until things drop (mostly gpus) in price even further. I'd also look into gaming laptops too, I got a great deal on a Legion 5 Pro with a RTX3070, 5800h 8 core, 32GB, 1TB nvme for £1300.
Nows really not the time to be building anything unless you can get cards for msrp which is impossible usually lol
This is probably the best your going to get for that budget right now so not great really but I have seen RTX 3000 series systems start for around 1K.
My basket at Overclockers UK:
  • 1 x OcUK Gaming Kinetic B4 - Intel B460 Configurable Comet Lake DDR4 Gaming PC = £863.95
    • Memory:Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
    • Graphics Card:*Build Stock* Asus GeForce GTX 1660 Super Dual Evo OC 6GB Graphics Card
    • Primary Solid State Drive:WD Blue SN550 500GB SSD NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS500G2B0C)
    • Secondary 2.5" Solid State Drive :Unwanted
    • 3.5" Mechanical Storage Drive:Unwanted
    • Operating System:Unwanted
    • Security Software:Unwanted
    • Case:Kolink Citadel Micro-ATX Case - Black
    • Additional Lighting:Unwanted
    • WIFI:Unwanted
Total: £878.05 (includes shipping: £14.10)
  • 1 x OcUK Tech Labs AMD Ryzen Home & Small Office Micro ATX Configurator = £553.87
    • Case:Kolink KLM-003 Micro-ATX Case - Black
    • Memory:Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey
    • Primary Drive:Seagate 250GB 2.5" BarraCuda 120 SATA Solid State Drive - *System Stock* (ZA250CM10003)
    • Secondary Drive:Seagate BarraCuda 2TB 7200RPM 256MB Cache Hard Drive - *System Stock*
    • Graphics Card (MUST BE SELECTED IF CPU DOES NOT HAVE VEGA GRAPHICS):Unwanted
    • Optical Drive **Please Check Chassis Support**:Unwanted
    • Power Supply:Kolink Classic Power 600W 80 Plus Bronze Power Supply
    • WIFI:Unwanted
    • Operating System:Microsoft Windows 10 Home Advanced - Systems
    • Build Time:Standard Build Systems - Dispatched in approx 10-15 working days
    • Keyboard & Mouse Set:Unwanted
    • Monitor:Unwanted
    • Processor:AMD Ryzen 3 3200G Quad Core 4.0GHz (Socket AM4) APU with RX Vega 8 Graphics - MPK
    • Motherboard:Gigabyte B450M-DS3H AMD B450 (Socket AM4) DDR4 Micro-ATX Motherboard
Total: £567.97 (includes shipping: £14.10)​
to get you going and save up for when decent gpus are a good price. no game types were mentioned, so vega of the ryzen should suffice
