PS4 Pro - Can I install a SSD without doing a 'backup'?
11 Jun 2004
Middlesex, London
Hi guys.
i just got my first PS4 Pro - It is used.
I want to install an SSD. Can I do this right now? before I use it ....or do I have to do a 'backup' first?
Thanks
Hi guys.
Thanks
If your installing an SSD you will need to reinstall all system software etc from a USB and it will format the drive while doing so.
So if you've already done a backup to a spare hard drive it's fine and you can recover after setting up the SSD.
If you haven't done one already then backup to a spare drive which isn't the SSD.
Thanks!
so I need to download the 'PS4 Re-installation file' and have it ready on a USB stick once I turn on the PS4 with the new SSD installed?
Thanks!
Yes, that will install the system software allowing the new hard drive to work with it.
