Caporegime
- 9 Nov 2009
- Planet Earth
I have more chance going to a bar in 2021 then getting a GPU which supports bar.
The eurogamer 3060 review has some benchmarks with it enabled on a z490. Seems the benefits decrease as resolution increases. Be interesting to see what happens with the faster cards.
AFAIR it was 17% @ 1080p and 11% @ 1440p and 10% @ 4k
Eth hash rate is higher with rbar?
Well that didnt take long. Mining limiter has been bypassed being reported on reddit
Found it
Damn.. Nvidia actually under quoted the performance- digital foundry got 17% extra performance in battlefield V with resize bar on
resize bar performance gain in BFV with rtx3060
1080p: 17% more fps
1440p: 15% more fps
4k: 7% more fps
Will be interesting to see how these numbers change on more powerful cards next month - the 6800xt gets 2% extra performance in the same game when SAM is turned on
"Interestingly i saw a similar rise to framerates on AMD too in this title"Where are you getting the 6800 XT results from, Hardware Unboxed?
If so it may not be a fair comparison as DF tested using DX12 and HUB tested using DX11.
Not sure what effect a different API has on SAM perf.
Link cause I don't see anything or are you just repeating rumours from ransoms?
