- 21 Jul 2005
- Officially least sunny location -Ronskistats
R-bar is magical. If you call it SAM it will only give you 2% increase. If you call it Rbar it will give you over 15% increase.![]()
Not only that but it also improves the image quality on Nvidia cards a lot better than AMD cards by 3.14159% !!!R-bar is magical. If you call it SAM it will only give you 2% increase. If you call it Rbar it will give you over 15% increase.![]()
AFAIR it was 17% @ 1080p and 11% @ 1440p and 10% @ 4k
That's massive increase. I guess infinity cache and narrow bus might not be working too well with Sam on Navi.
I have a Gigabyte X570 Master, a Gigabyte 3080 Xtreme and a 5900X. Both my mobo and gpu are on the latest bios, in my mobo bios Re-Size Bar is set to auto, options are auto or disable. However, in the Nvidia system info page, it says Re-Size bar - No.
Any ideas?
The 3060 was only 4% faster in AC Valhalla with ReBar (although 11% faster on the lows), so a much lower improvement than the 15-20% that AMD gets. AMD are already extremely strong in BFV vs equivalent Nvidia cards, Nvidia have a lot of catching up to do.So nvidia have done a better job than AMD then with this tech?
What happened to the "more vram and re-size bar/SAM enabled will show up cards with less VRAM"![]()
https://www.computerbase.de/2021-02/geforce-rtx-3060-asus-msi-test/
Yes the cards they launched 2 years ago and the chips from the consoles. All of them are better than 3060.Do AMD have an equivalent to the 3060 yet?
DF said that AMD had the same perf increase in BFV as the 3060 but why arguing? Let Nvidia owners think Jensen is a genius that can give them more perf by changing a name.The 3060 was only 4% faster in AC Valhalla with ReBar (although 11% faster on the lows), so a much lower improvement than the 15-20% that AMD gets. AMD are already extremely strong in BFV vs equivalent Nvidia cards, Nvidia have a lot of catching up to do.
Only the 3060 has the BIOS for it; other cards are getting it early March.
DF said that AMD had the same perf increase in BFV as the 3060 but why arguing? Let Nvidia owners think Jensen is a genius that can give them more perf by changing a name.![]()
Yeah the RX 5000 series supports SAM/RBar as far as I know.Do they support RBAR so we can test like-for-like?
