Did your 3090 run at PCI-E 4 in the slot?
Have you applied any manual voltage to your SOC?
I ask because too high on the SOC can cause issues with PCIe 4 devices and you have 32Gb of ram at 3600MHz.
Can having 32Gb of ram at 3600MHz cause a problem then, just asking because I will be building a new system soon around a Ryzen 5 5600x and was thinking of getting that spec of memory with a X570 Tomahawk
I think it's just harder to run that than 2 x 8Gb as it's more taxing on the integrated memory controller on the CPU die to have all 4 slots populated.
If it's dual rank that's still harder than two single rank sticks.He says:
Am using 2 x Crucial Ballistix 16GB kits (BL2K8G36C16U4BL)
He says:
Got the spec in my sig and have a annoying problem with it.
When i first built it i could not get a signal to my monitor, had to change to PCI-E 3 to get it to work.
Not sure if this a fault with the mobo or GPU, or just a setting i have missed in bios.
Everything is running fine apart from the mentioned problem and was gonna give the new bios a try, but if i flash the bios it will go to Auto on the PCI-E so will likely get no signal again.
Any help would be appreciated.![]()
