I'm 5'5 and 105kg, you need to get those pies inDamn I'm 5ft5 and 60kg! I've been doing a sheer strength regime for a couple of years though. Not really focused on muscle mass growth nor fat cutting for now.
Used some nectar points and upgraded my non-smart composition scales to a smart one.
I got given the white ones and really like them. I also have the Blood Pressure monitor and sleep mat, so the Withings dashboard is quite handy. I like now, I weight myself most mornings and my weight gets synced to a few different places like Google Fit and Strava.
5ft 8" so within the normal range for my specifics given very low bodyfat % and the bulk of my weight being muscle mass which I'm in progress of increasing to reach as near to 65KG goal as possible. I cannot maintain excess bodyfat, it gets burnt off just being static lol let alone being active so everything I seem to gain is in muscle mass. 2 years ago I was 55KG before I figured it was time to get shredded as I can achieve this fairly quickly but need to keep home workouts consistent else I can lose weeks of results in a single week!
You're the exact same height and weight as my wife ha, she's also very fit and works on muscle mass.
I have male friends that are shorter and probably lighter than my e wife too, so it's not so bad
Bloomin' heck! I assume you're quite short?
That is my big gripe with the Show range. I wanted to use it as a baby monitor but it has a 5minute display limit. I setup iSpy to use the Firefox app but there is still a 10 minute view limit on Firefox. I want to use it for anything beyond this point in time interactions and it stops me.Now in situ compared to the one to be replaced.
Initial impressions.
- Sound quality much better.
- Screen is good.
- Swivel initially seems a gimmick but you actually get used to it is good.
- Shame there is not a native Iplayer app
- Screen is good.
Shame really as they are so inexpensive/easy to manage compared to a custom tablet setup or whatever.
