id be glad to able to help where I can but I'm not 100% on the forum so nit sure where to see trust info
UPDATE
I found it
I got the type C connector from overseas came with in a couple of weeks 2 screws didn't match up but had my own still would like to have it as standard was going 15 quid to get so I understand why it was left out to keep the cost down but not a great one
does your board have the fan headers set as voltage controlled in the bios, if so try changing to PWM signal instead.Anyone know why I'm getting front fan RGB working (synced with Asrock B450M Steel Legend), but fans aren't spinning?
Only one was spinning last night (top one), so I double checked everything is connected properly (front hub is as prescribed in the instructions) power from SATA, all three fans connected via the 4 pin cable to the daisy chain on the hub (3 pin won't connect to the daisy chain). And now none of the fans spin.
Absolutely flummoxed - but impressed with the thermals (even with one fan spinning and no exhaust, it's 20° cooler than current case!)
Would just like to get all three spinning.
Nevermind - apparently, these fancy Lian Li fans require their 3 pin cables to be wired up and powered, instead of the ones that run on unicorn farts and wishes, like I'm used to.
Well atleast you got it sorted
landed yesterday and are in stockAny idea when the Lancool mesh front panel kit in black will be back in stock?
