It won't fix the donkey in the back though... Unless they're allowed to cheat again this year![]()
There is speculation that last year they had to use a lower fuel flow restriction as punishment for the 2019 cheating, and should be back to normal flow rate this year.
I did see the rumours of that, I'm not sure I believe it personally but who knows. Seems a 'weird' arrangement - "We think you're cheating, but can't prove it, so lets come to some agreement that gimps you just for the next year, but you're not allowed to tell anyone you're being gimped..."
More likely they just had to use what everyone else was using, which meant they couldn't compensate for their poor aerodynamics with extra engine power.
Ferrari ailed to its worst season for 40 years in 2020 as it struggled with a draggy car design and poor power unit performance, the latter induced by a private settlement with the FIA over its 2019 engine.
Whilst I don't read a huge amount into it, it keeps being circulated, so possibly some truth to it e.g. even in @JRS link above
@Armageus - yeah, I can't quite decide if everyone is just citing the same piece of conjecture/projection/nonsense (choose your preference) with that or if it's genuinely true.
If it is true then I reserve the right to hang lampshades on the OcUK Motorsport forum's obsession with non-existent pro-Ferrari bias at the FIA![]()
There's some discussion of it over here:
https://www.f1technical.net/forum/viewtopic.php?f=4&t=21958&start=5550
basically it stems from a comment made by Mika Salo, but it's likely been mis-translated or taken out of context.
However it sounds like the 2020 engine was perhaps still designed for the 2019 fuel flow (i.e. with cheat), and therefore the Turbo etc wasn't sized adequately for lower fuel flow. The turbo has now been downsized for 2021, so perhaps should perform more optimumly etc.
https://www.motorsport.com/f1/news/f1-reveals-jeddah-street-circuit-saudi-gp/5783551/
This is going to be rubbish isn't it!
The onboard makes it look even worse than I thought after seeing the layout.
Probably bore-fest; much rather see Nurburgring or Mugello back instead of this
Looks like an even more bland version of Sochi.
